Advance/retard timing on EZ116K
  • Thread starter Thread starter frpe82
  • Start date Start date
Interesting reading about the ICU mod to a LH3.1.
Question: Will it work with ECU # 0 280 000 572?
That's the ECU in my 91 245 M47 LH 3.1.
as mentioned above the mod is to the EZK box
the mod works fine on my LH3.1 car, but no were near as well as a good ignition chip .
Did this mod yesterday in a 1993 244 with an automatic, ipd VX cam and ipd exhaust. Did four 0-60 runs (two standard timing, two advanced) with 3 guys in the car (about 3550 lbs total) with a GTech Pro and got 11.45 and 11.27 for standard timing and 11.07 and 10.91 for the +3. The math says that's a 3-5 hp pickup. Not bad for almost free.
So what about using an old dizzy like i have installed now, the one with mechanical and vacuum adv. i have it set right in the middle on the adjustment area. Is it neccasary to do thid mid with that particular dizzy since its always adjusting via eng rpm and vacuum. or should i get one thats non-adjustable and perform mod??
noob question: complete electricity noob; what is meant by "grounding"... take the desired pin out of the connector and ground it, or splice a wire from ground to desired wire/pin?
and where the heck is the ezk box in a ?93 940? EDIT; nevermind, finally found out about location of the ezk in the chipping faq
if running high boost with the cam advance wouldnt you want to retard the timing to prevent detonation/preig?
which is better? leave cam straight up and advance timing or advance cam/ retard timing on boosted b230ft lh 2.2?
We'll I ran high boost and used the timing advance grounding trick and also used E85.... So depends on your fuel also...
Also if your running lh2.2 you can adjust your timing by moving your distibutor, this is for lh2.4....
Like pete says above you switch it with the car off, don't do it on the fly...
complete electricity noob question; what is meant by "grounding"?... take the desired pin out of the connector and ground it, or splice a wire from desired wire/pin to ground?
okay, so the ones i want to ground, 18+19 for instance, I wire from connector to ground? thet rest of the wire is just not for use?
So pin 18 + 19 straigth from connector to ground?
(Sorry, noob :-/ )
Yes and the other trick is there usually isn't any of those pins and wires in the 18 or 19 but you can get those pins and wires from say the radio plug or other plugs in any old volvo harness you have laying around.
right were too start. im from the uk, got a 95' 940 estate with the b230FK engine, mods are... t28 turbo custom exhaust brought a sst chip for the ecu which has had the fuel cut removed and also the rev limiter removed aswell, with these mod on and working im able to run 1.0bar of boost (14-15psi) but nothing more that that other wise i get shut down and loose all power but does come back after a few seconds. Im interested to know that if i do the ezk mod would this get rid of the shut down also stop the pinging that im getting. cheers for any help :)
Great read, I missed this whole topic back in the day :-)
In case anyone needs to know - the terminals (from AMP/TE) are called "JPT", Junior Power Timer 2.3mm EXAMPLE. You can get them just about anywhere these days, Amazon, eBay, Aliexpress, etc., in addition to 'professional' sources such as Mouser. Newer style have the spring tab, originals from mid 90's or older may not.
I guess that isn't the right one for ICU and ECU plug. Those have only one lock tab.
The Junior Timer series has 1 locking tab, and the Junior Power Timer series has 2 locking tabs. I don't know if the 2-tab pins will work OK in a 1-tab housing. Here's a good starting reference for the pins and housings:
I guess that isn't the right one for ICU and ECU plug. Those have only one lock tab.(
(EDIT) I KNOW they do. I've done it on (L-Jet, LH-Jet, EZK) ECU connectors. The only issue is if you try & use the waterproofed (male) version, those won't lock in the housings, but that's not relevant to this conversation.. All AMP/TE (K/D(Lambda)/L-Jet) ECU connectors have provision (space) for 2 tab terminals, even though only one tab will lock.
EDIT again - also, unlike the single tab, these provide a more lasting connection, due the spring tab maintaining anchoring tension on the 'prongs' to the male terminal in the ECU.
Edit - I took a couple of pics of an early single tab style housing, and the later two-tab timer connection. I'll add them later
