aussyvolvo
Will stalk for money
- Jul 12, 2007
- South Australia
Hi, I'm trying to put an altinator on this engine, and I need to see how others do it. Do you run dual belts, with the alt on the bottom left, or single with it high right?
I have a spare lower left, but both belts interfear with the timing marker shroud. Could I use a small spacer and run 1 belt?
1 last question, I haven't looked at volvo engines in so long, can someone tell me the difference between the aq171a, aq171b, and aq17c? And what other blocks the crank/rods/pistons/head are compatable with (ie. b200, b23e, b230ft, or b234f?)
