wgusler
- May 10, 2016
- Apopka, Florida US
My next adventure was to find out why the auto lock worked intermittently or not at all. A search here pointed out the wire problem so off with the door panel. The harness at the lower connection had some flakey wire insulation, but nothing really bad. But moving up to the actuator YIKES!
Then the lock sensor............
I figured it was all trashed and then looked for a replacement, 160.00 on ebay used. Umm, nope. I took it all to the bench and made a new harness to connect to the old crusty ends.
I used some T100 to clean the corrosion and gunk off the wires and soldered new wire to the old ends and color coded shrink on the actuator and lock sensor and butted it up as close as possible to the units.
Attached to the new harness and then the OEM plug connector.
I was actually shocked that it worked perfectly.
