bobxyz
- Aug 29, 2014
- Boulder CO
Overview
Over the last few years, simple handheld battery-powered oscilloscopes have become available for less than $40. This thread is about the FNIRSI DSO152 oscilloscope, and how it can be used for automotive diagnostics. The examples here are from a Volvo Redblock Engine with a Bosch LH2.4 Fuel Injection System (pre OBD-II). Many other cars of the same era, late 1980s and early 1990s, have similar systems.
The information is split up over several posts:
- Overview and What to Buy
- Basic Oscilloscope Configuration and Adjusting Probe Compensation
- Ignition Waveforms: Crankshaft Position Sensor (CPS), Ignition Powerstage, Coil Primary and Secondary
- Fueling Waveforms: Mass AirFlow sensor (MAF), Injectors and Narrowband Oxygen Sensor
- Miscellaneous Waveforms: Battery, Alternator, VSS, CAN, MegaSquirt, etc.
- Summary and Links for Additional Information
TLDR: for less than $40, the DSO152 works well for many basic engine diagnostics. It lacks the storage and triggering capabilities needed for detailed waveform analysis but is fine for a simple check that a waveform is present and the sensor/circuit isn't completely dead.
What to Buy
The FNIRSI DSO152 is currently #1 on the Amazon Oscilloscope Best Seller List:
https://www.amazon.com/gp/bestsellers/industrial/393269011
You want to get the Deluxe version that includes a 1x/10x oscilloscope probe with a BNC-to-MCX adapter:
https://www.amazon.com/FNIRSI-DSO152-Oscilloscope-Automotive-Bandwidth/dp/B0C6XPVLPZ
A few test leads and some sewing pins (size 20 straight pins 1 1/4" ball point) or 1 1/4" T-pins will make probing easier. These aren't essential - you can just hold the scope probe on the back of the connector pin, but it's easier to use the T-pins and test leads so that your hands are free for other tasks.
When probing the connectors, the T-pin, or sewing pin, is inserted from the back side of the connector next to the crimp on the connector pin. Resting the head of the pin on the rubber connector boot provides enough side force to make a good electrical contact. Do NOT drive the pin into the wire or into the connector pin, or else damage may occur.
https://www.amazon.com/Sumnacon-Multimeter-Electrical-Test-Clips/dp/B07T2XX8PD
An Altoids box works well to store the pins and other small parts.
Before getting started, plug the scope into a USB-C charger. A tiny red LED next to the USB connector will light up, and will change to green once the battery is fully charged. The battery should be good for a couple hours of usage.
What to Buy
