tomasss
former PRVert
- Oct 13, 2008
- Sydney, Australia
So I have an issue with oil pressure build up after the engine rebuild (16v 2.0 turbo). Engine filled with oil, spark plugs removed, oil pressure gauge in the oil pressure sensor hole & trying to get some oil pressure reading while cranking.
Several cranking attempts done, zero reading. Then I have checked the oil filter and it's empty. I am sure I installed the oil sump oring correctly and also the oil pump seal. So I guess the issue is just the dry oil pump?
How should I proceed? On the picture below it seems I could inject some oil through the relief valve(2)? Should I fill the oil filter? And how much if so (I have been reading that all the way up can also cause issues?).
