B230 HARDWARE LIST
3wagons
NW GA
This will be an ongoing project. I've been compiling a list of hardware as I have been freshening up 3 late B230s in the shop. More to come. Open to suggestions on how to present this info in a better way. If I ever get a computer in the shop, I have considered posting pics of the part and bolt along with the dimensional info.
Google Docs Link
PartHardware TypeDiameter/PitchLengthFull/Partial ThreadSocket SizeQuantity
FRONT CRANK COVERBOLTM6x1.016MMFT10MM
6​
FRONT CRANK COVERNUTM6x1.010MM
4​
FRONT CRANK COVERSTUDM6x1.040MM
2​
REAR MAIN SEAL RETAINERBOLTM6x1.016MMFT10MM
6​
OIL PANBOLTM8x1.2514MMFT12MM
18​
OIL PUMPBOLTM8x1.2525MMFT12MM
2​
PCV BOXBOLTM8x1.2525MMFT12MM
2​
WATER PUMP TO BLOCKBOLTM6x1.030MMPT10MM
3​
WATER PUMP TO BLOCKSTUDM6x1.040MM
2​
WATER PUMP TO BLOCKNUTM6x1.010MM
2​
WATER BYPASS PIPE TO PUMPBOLTM6x1.025MM10MM
1​
WATER BYPASS PIPE TO PUMPNUTM6x1.010MM
1​
WATER BYPASS PIPE TO BLOCKBOLTM8x1.2516MM12MM
1​
WATER PUMP PULLEY w/o FAN CLUTCHBOLTM6x1.016MMFT10MM
4​
CRANK POSITION SENSOR BRACKETBOLTM6x1.025MM10MM
2​
CPS TO BRACKETBOLTM6x1.014MM10MM
1​
KNOCK SENSOR FOR LH 2.4BOLTM8x1.2530MMFT12MM
1​
DIPSTICK TUBE TO BLOCKBOLTM8x1.2516MMFT12MM
1​
DISTRIBUTOR - BLOCK MOUNTEDBOLTM8X1.2512MM
1​
DISTRIBUTOR - HEAD MOUNTEDBOLTM6x1.016MM12MM
2​
TIMING COVER - UPPERBOLTM6x1.045MM10MM
1​
TIMING COVER - UPPERBOLTM6x1.030MM10MM
1​
TIMING COVER - UPPERBOLTM8x1.2555MM12MM
1​
TIMING COVER - UPPERSCREW
1​
TIMING COVER - LOWERBOLTM6x1.030MMPT10MM
1​
TIMING COVER - LOWERBOLTM8x1.2530MMFT12MM
1​
940 DRIVER SIDE ACCESSORY MOUNTBOLTM10x1.2530MM
5​
7/9 DRIVER SIDE MOTOR MOUNT TO BLOCKBOLTM8x1.2540MMPT12MM
3​
7/9 PASS MOTOR MOUNT TO BLOCKBOLTM8x1.2535MMPT12MM
4​
7/9 POWER STEERING BRACKET TO BLOCKBOLTM8x1.2530MMFT12MM
3​
7/9 P.S. PUMP TENSIONER TO BLOCKBOLTM8x1.2520MMFT12MM
1​
7/9 P.S. PUMP LONG BOLT TO BRACKETBOLTM8x1.2580MMPT12MM
1​
7/9 P.S. PUMP LONG BOLT TO BRACKETNUTM8x1.25LOCK NUT12MM
1​
FLYWHEEL/FLEXPLATE TO CRANKBOLTM10x1.525MMFT GRADE 12.917MM
8​
PRESSURE PLATE TO FLYWHEELBOLTM8X1.2520MMALLEN HEAD6MM ALLEN
6​
This is a really good start. May I suggest putting this in a google docs spreadsheet? They can be accessed from anywhere and you can add multiple contributors to one. Plus, it's less likely to get corrupted, or lost, like a lot of info on this board already has.
Good call. I'll toss the link in the first post. I will try to keep the table in the first post current as well unless it grows too large. As I work on stuff at the house I will add to it. All of this because I wanted new oil pan bolts and couldn't find a size posted anywhere...
I'll add.
The plugs on the rear of the engine are 1/4" NPT
The front is also 1/4NPT
Above the oil pressure sensor near the head under cylinder 2 is 3/8 NPT
Jordan
