B230 question, does anyone know the size of this oil feed
James M
Bored member
Davis / Chico, CA
I have never found that port to be a better option than the stock oil pressure sensor feed port, but if that is the way you would like to go, go ahead
Edw
thanks, 1/4 npt seems correct. Im using it as oil feed to the turbo
conehead
I had a harder time finding the right size piece to plug up the old feed on the side than I thought I would, are you going to be pluggin the old feed or are you adding a gauge or something?
