B230FT MS2.2 wiring harness
REDBLOCK-RIPPER
So I'm swapping my dad's old 87 b230 ft into my GT we have the ignition side of the harness but lack injectors and sensors etc there is this 12 point connector that I believe would connect to all that but on the other harnesses I've seen that's not the case anybody know what I'm looking for?
That's not a factory connector, but it might be similar to one. The factory engine compartment harnesses use a 9-pin or 11-pin connector in the passenger's footwell to connect to the starter switch, the fuel pumps, and some dashboard gauges. Go to https://www.240turbo.com/PinFunction1989-93-240LH.html#p1 and scroll down to Page 6 for pinouts of the factor 9-pin and 11-pin connectors.
You'll need to list and trace all the wires going to that connector - you may be able to trace them visually or with an ohm meter.
