B23FT M46 swap clutch parts
Me too! I did a lot of work on the car and didn't charge enough money for my labor or the parts (in retrospective).
I suppose I could see not charging a lot with the idea you were doing the work for your future self when you eventually bought the car.
My guess is that car has either been crushed or is currently in Europe because such a spec’d Volvo doesn’t stay off the grid in the US nowadays
This is good info. Anything regarding this unicorn as f**k drivetrain setup helps. I know the hydro clutch setup was developed and in use at this time because the manual transmission 260’s had hydro clutches, but given they stayed with cable clutch setups on B21FT cars it would make sense if they used a cable setup for the B23FT.
Roy, do you know if those ‘84 760’s you saw had original M46 hydraulic clutch setups? Or had they been converted/swapped?
I just saw your question. They were both factory built cars that came stock with the M46. Both were hydraulic clutch.
