I’m familiar with how they are lubed from the factory, I’m just curious if you were going to pressure feed oil through the rocker to the adjuster cup. If you’re going this route you’d want to use a lifter with an oil feed hole on the face of it as well.
I’m a big fan of the OEM lifters. They’re a lot lighter than the GM ones, and it’s cheap enough to get them lapped and DLC coated if you are really worried about them.
I need to get a pushrod block to poke around (plenty of heads) to see how difficult a lifter spray/drip bar would be. Also, looking into bushing and reaming the lifter bores or converting them to a roller lifter setup. Easy one you have the right machinery (which I now do)
