pat244ti
Moderator
- Dec 23, 2002
- Santa Cruz CA
So before I got rid of these pictures from my phone forever, I figured I would post them for those who are wondering what is needed for this. I did a search on it and came up with nothing but upon further fiddling, it's pretty easy.
I bought a modded [by The Full Banana] B21F intake, set up with injector bungs and modified for a 960 throttle body. The stock 960 TPS, while ideal for it's variable signal for applications with Megasquirt or other aftermarket EMS, is not compatible with LH 2.2/2.4.
First, you need a 960 throttle body, LH TPS, a #30 dril bit, a M4 tap and some short M4 screws, washers and lock washers.
Take apart your throttle body and you will end up with a pile of parts like this. The screws holding the throttle plate to the shaft are T15 and usually on there pretty good, be careful.
Re insert the shaft [thats what she said], but with the threads facing up towards the inlet of the throttle body [she probably didnt say that.]
Mine was facing the other way, and this was to orient the connector for the TPS pointing towards the engine [stock]. With it set up like this on my manifold [modded B21F] this was absolutely necessary to make this work otherwise the TPS would hit the manifold. May or may not be for what you are using it for
So with the TPS on there, you can see from this side view there are little "posts" on the edge of the throttle body that line up perfect with the slots on the side of the TPS to bolt it on there. All you have to do is drill and tap those "posts" with the M4 tap as centered as possible. Than mount up the TPS and getting adjusted all nice
And the finished product
