Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
Need some files to start a base map and or just advice am I able to pull the files from my factory chips and go from there if anyone has files to share I would sure appreciate it
A few stock and aftermarket chip bin/xdfs files are there, so you can see what they have changed or not changed. The KL ezk timing map is about right for a maxed out 13c/15g/16t car.
Remember to put the LHCsum.dll file in the tunerpro folder (or the folder where your bin files are) before saving the fuel bin, otherwise it won't work.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
