Bosch power stage AKA ignition control unit heat conducting paste
Blowbig
Ballard, WA
Every couple of years I replace the power stage, FPR, supression relay and CPS for good measure. The new Bosch 0 227 100 124 doesn't come with the "heat conducting paste" anymore. Checked with Worldpac and they opened a few others to see if this one went missing - none of them come with the paste. I was told by an old-timey Volvo tech that that stuff was really important. Anyone know what to use in place of this? Thanks.
From TB's own cleanflametrap (Art Bernstein) on brickboard -- "I left one of mine dangle from its wiring for 3 months of summer while driving around with a spare in the cubby. Mostly I wanted to see for myself how little heat they really generate in use, as I suspected, given all the hand-wringing over heat sink compound being done on this board.
It (on its original heat sink and compound) got warm, especially after a long drive, but never warm enough to be uncomfortable to hold in the hand tightly, meaning its dependence on the fender for heat dissipation is nil."
FWIW
Thanks. There's a Staples 3 doors down so that was easy. I know I'm weird. $100 in the commonly failed stuff every 5 years may as well do it 100%.
I used artic silver because im a computer nerd and thats what i had laying around.
If you really wanna nerd up your powerstage..
FWIW
Hey Michael, I read this forum too, FWIW. My guess is a dab of zinc oxide (diaper ointment) would last as long as the original Wakefield compound in this application.
Also I used some nerd skills to keep an old PC practical with a delidding adventure, which might be a better place to use that liquid metal.
And, I've had some extremely good luck with the longevity of the EZK power stage in my own cars, all the originals still making reliable spark, but finally I have run across two that failed in others' cars. I suspect anyone who needs to replace them more often than twice every 30 years should suspect the ignition coil may have shorted turns, rather than dried-out thermal interface compound. This one failed at the package to die bonding; could have been thermal fatigue in the wire carrying the current.
-Art Benstein
Thermal paste I honestly did not know about! I've had mine off to clean the pins, connector and mounting surface and had no clue. The power stage on my 91 didn't have any paste under it or on it's fasteners when I took it off. I did use a bit of copper anti-sieze on the bolts and a touch of dielectric/zinc paste on the pins when I reinstalled it. Who knew.
I believe I found a DIN equivalent of the OE paste; ended up buying something from Amazon I believe that met those specs.
Those transistors get HOT..... take them loose some time after driving and check the backside with your IR gun. I'll run the paste to conduct that heat into the aluminum base, and then to the inner fender on the 7/9 location.
...The power stage on my 91 didn't have any paste under it or on it's fasteners when I took it off. ...
The paste is between the module and a small heat sink block. The heat sink block is what you mount to the fender, and it, I guess, is not normally supplied when you buy a new module. My spares came from the pick'n'pull so I haven't needed to separate the module from the heat sink or renew the paste.
Edit: Adding some pics to illustrate the added complication arising from the corrosive environment next to the battery in a 240.
:nod:
https://youtu.be/SJvCVs2NiF0
FWIW
Mounting it to the fender has a negligible change or effect on cooling. The thermal compound goes between the power stage and the heat sink... not between the fender and the heat sink
Sheet steel is not very thermally conductive. The area behind the heat sink will heat soak quickly and no longer provide any value. Its going to get most of its dissipation from radiation and convection cooling. There is a lot of moving air in the engine bay from the vehicle speed or the cooling fan.
I believe the 7/9 has a hole in the inner fender sheet steel for the "forced convection" to remove the heat from the finned backside of the EZK heat sink.
That heat has got to go..... either via large thermal mass (as the 960 power stages are mounted to the aluminum intake) or via convection to the moving air within the inner fender volume. Those areas must have positive pressure when the vehicle is moving, or the Engineers would not have sourced intake air from that space (turbo vehicles).
Read the BOSCH technical spec for the 203 power stage...... it specifies the conductive paste, IIRC.
-Art Benstein
Hi Art, Doug Day in Maine with one rebuilt 240 under my belt, one 940, original to the family, having served three kids, and two "new" 240s awaiting the sun for resurrection. ('87 240 manual wagon; '93 240 sedan, recently sitting for two years due to hard start, possible overheat, other basic neglect.). I'm holding the EZK power stage (ignition amplifier module) in my hand, wondering how to test it. I have a tiny or No Spark issue I'm trying to diagnose. Should I open this to inspect like your example here? Or leave it alone until I check all grounds, change wires, plugs, etc.? Am I likely to make things worse by opening it? It's just (now) a $35 or $55 part, depending, but I have so many parts I'm getting more careful about not fixing what ain't broke. Thanks for your comprehensive and clear write ups! Very good and helpful. Doug Day, Rockport, ME
I didn't open it to fix it. I opened it to show where it was broken. Testing it is normally a matter of substituting a known good one. I think you are correct; you'd make it worse if you opened it. Good idea to shine up all the connections -- at the coil primary terminals, the two-pin harness connector, and the module connector too. Battery fumes in that area make me suspicious of invisible corrosion causing poor connections.
