Alden
ALDORF THE DESTROYER OF WHITE SHIRTS
- Sep 29, 2008
- Pittsburgh PA
Fix all oil leaks. Especially the distributor. It will leak all over your RPM sensor and cause problems.
Adjust the valves and put in new silencers.
Do a ghetto tune up and sand down the distributor contacts if you dont want to buy another $50 cap.
Change plugs, clean PCV system, change old vac hoses, fuel filter, inspect brakes, change coolant and thermostat, top off tranny, inspect diff fluid level, air filter, and anything else that wears out. Too lazy to think about it all and type it.
