Bulbs for 760/960 eCodes
lookforjoe
Making Volvo Parts Fit
Rockland County, NY
I have the old Ecodes from my 960 - stored for the last 15 years - going to use them in my '91 745 - I don't recall what the 3 bulbs that are used with them. No markings on them to indicate
Anyone know offhand? H1? H4?
Fa182
Stage 1
Austria
From my 97/98 Greenbook:
First picture is for low / high beams (pins 1,2) and second picture is for the fogs (pin 3)
Ground for both is pin 4.
Fa182
Stage 1
Austria
It's the high beam.
That is wrong.
The lower inner H3 is the fog light.
The upper inner H3 is the high beam.
It's been a while, but as far as I can remember you can only adjust the fog lights horizontally, not vertically with adjuster knob.
So there must be something wrong with the insert, it's a separate piece from the big reflector that is held in via a clip or something. I don't remember exactly.
Part 27 on the diagram.
lookforjoe
Rockland County, NY
That is wrong.
Many thanks for the confirmation & schematic. I'll have to take it off & see what I can see with the innards. The Depot version has simplified adjusters (only two, no center one) - the inner does the height, the outers do nothing...
lummert
Portland IN
Thinking you may have to do a bit of work to fit 760/960 front light and grille parts to a 740. Maybe with mounting parts from a 940.
lookforjoe
Rockland County, NY
Its not bad at all on a 91 - just had to modify (cut & weld) the inner metal mount brackets for the revised offset, and trim the plastic filler cap
