canadiangt
- Nov 19, 2002
- Edmonton Alberta
I am getting all of the final parts together for a megasquirt installation. Since I am going to change the head gasket anyways, I am wondering if I can use the 405 head I have laying around. It is a BCP, but I am wondering if anyone is using one and if they have had the problem with the head cracking or breaking. I know that it is 1.5mm larger bore and 2cc larger. I figure that you would have to cut the head .017" to yield the same c/r, but the head FAQ states that a cut head is very weak. is this under boost or under detonation? I would probably be running it with an A cam, advanced 4 degrees and the turbo exhaust valves. Would the reduced height and incresed lift make it an interference engine? How about if I used a K cam. I think I would only have the head shaved .010.
Any help would be appreciated.
