hessam69
- Jun 19, 2009
- Sydney, Australia
Is there an equivalent page for a 240 conversion?
I’m too lazy to search.
Everything i have posted is 240 relatedIs there an equivalent page for a 240 conversion?
Yours is quiet? What fluid are you using?So, put a few miles on mine.
Setup is:
B21ft
Cd00a(brand new)
Yoshifab stage 3 clutch and flywheel, throwout bearing, crossmember,driveshaft
Deeworks adapter.
Autosports engineering top mount shifter.
Factory 3.73 gearing.
Wilwood clutch pedal and master, with puller slave
First off this swap almost broke me, but I think it was worth it. I absolutely love the gearing.
The box is quiet, I don't hear any noise like others have stated.
It's a whole different car now and I love it.
Anyone use the Autosports shifter for the 240? The gears are very close together, and apparently I was supposed to take some material off of the side detents, but I never did it. Just curious on if anyone else has used it.
Redline 80w90 + mt90 mix. That was recommended by the 350z forums a bunch of times.Yours is quiet? What fluid are you using?
