bobxyz
- Aug 29, 2014
- Boulder CO
Since I'm posting pictures tonight, here's the central locking switch harness out of my '85 245 driver's door. The circular collar goes around the lock cylinder, and the black cylindrical one is part of the lock pull -- pull up extra and all doors (plus trunk/tailgate) unlock, push down extra and all lock.
picture of installed collar (thanks volvogeek)
and a picture from the web
My central locking was originally inoperative due to the relay ground wires accidentally being left floating after a PO fan replacement. I re-grounded them but the locking was intermittent. The door lock and the pull-to-unlock were OK, but the push-to-lock caused both relays to click with no actual locking. Pulling the switches out of the door, I was amazed that they worked at all and weren't completely shorted out. The switches ground one of two relay wires (or two of two wires when shorted in my case).
I found a better lock harness at the salvage yard from a '93, but still needed to splice in good wires to the bare wires coming out of the lock collar. I was able to disassemble the lock collar and clean up the internals, but you'd probably do fine just spraying contact cleaner in through the gap and cycling the switch. The cylindrical lock pull switch seems glued together and I couldn't disassemble it.
The door harness goes through a 3-wire harness connector above the driver's left knee - red/green/black (Christmas sort of). If your locks are acting up, disconnect this harness or the relays/door solenoids may get stuck on and drain your battery.
If you replace your switches, look in the bottom of the door under the switches and you'll find a colorful collection of insulation crumbs.
-Bob
-Bob
