What did you do for the Volvo OP and coolant gauge senders? Do they need an adaptor for the stock GM block & head location?
Yep, that's basically it.
I havne't gotten there yet, I was originally thinking of just running the sensors to an aftermarket pod on my pillar mount but I wouldn't mind using an adapter to run them on the stock volvo sensors
Understood.
Hey Corivus - another question - did you have to deal with a VATS bypass of some kind? My drivetrain is 2004 - looks the same as yours - did you need to address that? Can't seem to get a definitive answer.
Yes I had brandon at lt1swap disable it I spoke with him over the phone and then sent him my pcm to remove all the things that wouldn't be needed. the big plus is he does not lock his tunes which is great if you are like me and down the road want to get your feet wet in tuning a bit more heavily then just using diyautotune.
So after responding to someone on FB about shifter linkage I realized the hodgepodge setup I made was lost when the DB had to be restored for TB. That said I'll try and explain whats going on in the photos I'm including on this post.
I originally used the Chevy silverado shift cable and discovered that its waaaaaay to long. I looked into getting a custom one made by a driveline shop and apparrently no one will fabricate custom ones locally anymore. Before going off and finding somewhere online I checked on v8volvos and one of the members mentioned the Dodge charger shifter cable worked for him perfectly. Thats where this comes into play, it looks long but it really only loops about a foot or so and I think I've managed to find a way to keep it from getting in the way of anything.
I think that covers my shift cable setup? I'm using the stock volvo shifter mostly because I wanted to have as stock of a feel as possible from the inside.
Any specific year Charger? I think I'll copy you on this - I want to keep the stock shifter. Unless there is a shorter cable option, yours looks good. Nice work on figuring out the bracketry.
You driveshaft looks like it not seated in the trans very far?
So I used one out of a 6th gen charger (Challengers and Chrysler 300's work as well) so I'm not sure about the 7th gen ones. but it was pretty easy to just walk into the first yard and find 7 different 6th gens in the yard.
And yes i thought the same and have tried seating it in without anything connected and can't get it to go further in then that. the gm end I used was the one that "came" with it and stuck out that far as well no matter how many times I tried to reseat it.
Can you clarify "6th gen" I don't know anything about American cars. If you can give me a year I'll research that - I'm assuming for auto trans?
The driveshaft seats all the way in my trans, up to the yoke. How much insertion depth do you have?
2006-2010
I'll check when i'm finally back at the shop with covid haven't been there all week to poke at anything.
Thank you fo all you help - I hope you recover soon!
This is a small update really, all the big stuff is mostly done outside of exhaust.
This is the walkthrough I'm using right now on building my harness. [img][img]https://lt1swap.com/Gen3_harness_mods_LT1SWAP_comHQ.pdf
ok looked back on my notes and apparently I didn't have that issue as my harness came from the same year as his so it wasn't something I noted. I will say I'm going to be pulling the engine and trans hopefully next week if its slow enough at work (I didn't schedule any one this week so it should be) so once I have the harness I'll poke at it to see where those go if you haven't already figured it out.Revised the link, the way you posted it it didn't work
Do you know where the range selector wires go to? They weren't part of the main harness on mine, and I can't figure out from the LT1 post where they even go to.
