corivus
Hey Shiny!!
- Aug 19, 2004
- Tempe, Arizona
Hey there, Just a video update(headphones for the low rumble noises) of where I'm at:
So, the throttle body issue ended up being multiple things, first off, the throttle plate was not moving physically. I fully disassembled it, mostly because 800 for a new electronic throttle body wasn't ideal, and then soaked all the non-electronic parts in transmission fluid for 2 days. After that a little articulating back and forth and it was moving like a brand-new throttle body again. I reassembled the whole thing and reinstalled it and I had throttle control back... for 1 minute. Pulled the codes again and got 1517 and 1518 this time... so I started checking wiring/grounds/etc. and finally decided to change out the TAC module with my other spare that has been inside the car this whole time.
I have been parking outside without the hood for a while and we got a LOT of rain which while not uncommon during the winter was a little unusual. Because of the work I’ve been doing the hood hasn’t been on the car. So, I haven't had time to start modifying the hood with how busy the shop has been but I am hoping I can start this Monday. I will be starting off with my worst hood out of the 3 I have to hopefully refine the process with one of the nicer white ones. That hood is the one in the video, it has lots of dents and paint rippling so I think it’s a perfect candidate. That said in between all the troubleshooting I had lost my fuel pump; I traced this back to a bad relay that became water logged. Swapped it out and yay I'm driving again, apparently burnouts are really easy to do so tires will be a thing once I get further along.
I think for now that’s really it for updates, I’ll be pulling the engine and transmission at some point to install the new oil pan and do a lot of other things but I feel like that will take some time. Also thelostartof is maybe going to take a day off and come weld up the exhaust so we can see what I need to change for cables and hoses, thankfully everything is ridiculously long so most everything can be moved around.
