Anson.drives
- Aug 29, 2025
- Washington state
So I’ve got this 89 240 in my shop atm. And for some reason injectors and spark only happens when the key goes from key 3 to key 2 (run)
No injector pulse while cranking and no spark while cranking
I’ve tested ignition stage module
fuel Ecu ,EZK,CPS, Coil
started with all the pin from the ignition switch falling out then repining that. I’ve used Daves schematics. But mostly the Bentley book for the diagrams. I’ve traced almost every wire in the system still no luck.
Also all the parts have been test on another 240 of the same year and runs perfectly fine.
I’ve been starting at theses diagrams all day smashing my head into a wall. Any input would be greatly appreciated.
