MJ Dan
- May 15, 2003
- Santa Rosa
Hi,
Got all the goodies,Thanks for your help..Starting to Design /make mounting brackets for my 740.
Here's a couple questions I have.
On the opposite side / end of the brake bleeders are allen plugs.
Can they be switched ? The plug is pretty tight so I wondered if you did the switch ? or did you guys just leave the brake bleeders pointing down.
Any problems bleeding the air out of the brakes with the bleeders pointing downward ?
