Dead time for stock injectors?
HiSPL
Fanking Champion 1993
College Station, TX
Does anybody know the actual dead time of the stock NA bosch injectors? Mine are from '88 LH2.2, but they are all the same I believe.
Search noob
Looks like 0.950 is the accepted "good enough" time.
Search noob
You can change the number of squirts per cycle and then dial your deadtime in so the AFR change is minimized. But then that's only at one voltage point. So then you have to do it at a lower and higher voltage point. It's a huge PITA. Or just do it at that one voltage point.
Though... Once you get the deadtime dialed in, it really makes swapping injectors without drastically changing the tune easy.
I just buy deka injectors with the data publicly available. It get's you close enough to say "F-it, that's good enough"
