diff is leaking oil again. I cannot for the life of me get the cover to seal. I have tried like 5 times so far
I had the same issue with my old 240. I tried just the cork. That didn't work well. I tried RTV. BIG no. I also tried a new cork with a thin layer of RTV, and that seemed to work best. I'm hoping somebody has tricks to share before I botch my girlfriends diff cover. lol
The RTV specifically made for differential covers has worked for me. The shop that rebuilt my axle and installed the truetrac recommended not using the paper gasket and using RTV instead
I cleaned thoroughly prior, followed instructions, and it's been sealed up now for about 5-8K miles, which means it'll probably stay sealed up
Steel diff covers use a gasket. It's recommend to use a Volvo gasket. Aluminum cover uses a sealant. I've personally used the green rtv andnd it works wel. No leaks to report.
Steel diff covers use a gasket. It's recommend to use a Volvo gasket. Aluminum cover uses a sealant. I've personally used the green rtv and it works well. No leaks to report.
Which years did the steel cover come on? I ordered a rubber looking diff gasket genuine Volvo.
But in all seriousness, that still sounds too loud even with the resonator. I'd be willing to bet your muffler is wasted. I didn't realize they could degrade internally until I took my old one off and looked inside. They have steel baffles inside that corrode away and eventually stop producing the acoustic effects that they were engineered to produce.
My car has no resonator and a new stock muffler. It is quieter than what I heard on your video... the only time I notice my car's exhaust it on the highway, when I hit the resonance around 2.5-2.7K RPM. Even then, it's not that loud, just could be quieter, ya know?
Sealed that rear differential yet?
If not:
https://www.quadratec.com/products/52416_100.htm
I used them on mostly 4wds... but it's for a Dana 30 and doesn't care what cover you have.
How far does it go? Can we get the idle down to 0db?
