I forgot to update this thread so here is the gist over the last 2.5 months
There is/was a break in the harness that I'd occasionally have to jiggle to get the car to run that bugged me enough to try to figure out why. It turned out to be the rpm signal from ezk to lh boxes was intermittent and was causing the lh box to not want to hold the fuel relay on. I've recieved another harness from Cwazywazy the other day and that will be going in.
I moved the wasted spark loot from the strut tower to the firewall. I want to switch to coil rear plug so this will be revised again soon.
The power steering pump has been making annoying noises so i got another from the junkyard and rebuilt it. I have yet to install this one.
The distributor wasn't doing anything and I wanted an additional crank case breather location so I pulled it. It was stuck in there good and did not want to come out. I ended up removing the intake piping and airbox and got a hammer under the lip to pop it out.
I installed a mann pro vent 100 in that new additional breather spot. It works really well. I temporarily plugged the other breather spot to see how well just the pro vent works without the stock breather box doing anything. It works crazy well.
I installed a mini battery. Odyssey PC680. It works well, cranks the car over fine every morning in 10F degree weather. Haven't had to test reserve capacity yet though!
The panhard bar mount to the axle had a failure, the stud itself snapped off the axle! I was able to limp it to work and had my friend come by after hours and weld on a new stud. Not sure how the original one failed, there was not significant corrosion in the area or anything, plus that stud should see no side loading.
Cleaning the wideband sensor. My controller died and I left the sensor in the exhaust stream unpowered for months. It seemed slower to respond than before and maybe this helped? not sure. Cleaned it off physically though
Bought some e codes, have yet to install.
My shifter is just a 14mm rod so i spruced it up with some mcmaster collars and bushings lol
Permanently installed an antenna mount in the roof. Feeding the coax through the headliner without removing it was terrible, but the install is so clean now.
Got some ipd strut brace goodies. I wanted the kaplhenke full strut brace but after waiting for 1.5 years now I gave up. I'll still buy one though if they're made again
