DSM BOV mod for quick release and higher boost
Magnum TE
Broke another B230F+T
Santa Rosa Ca
This was a great mod, I found it on donvian's dodge garage....
http://www.thedodgegarage.com/turbo_bov_mod.html
I highly recomend this if you have one of the DSM BOVs.
First thing if you are going to do this Do not use the 6mm tap like he says use a 5mm tap and drill a smaller (9/64?) piolet hole. the 3/16 brake line i used would actually slip through the piolet hole even before i cut the threads. So use a smaller hole and everything will be all good.
I also taped my pressure signal on the BOV flange so that was a short run of vac line.
Result: No more backlash! the valve open clean and fast every time. and it holds around 15# of boost (all ive tried so far)... although the car now idles at 1.5kRPM :( vac leak maybe... I am not sure yet.
If you have a DSM BOV that isnt working as good as you would like... Do this and see how much better it can be.
Pssshtt~!
Magnum TE
Santa Rosa Ca
no one on the board has a 1G DSM BOV??? I know htere are some of you who have them, take a look at this its really a good thing to try
nohbudi
Jesus Christ...
Toledo, OH
I now have mine installed, but have yet to do the mod on it... i will see if i like it as it is, or not yet.
GTJordan
Been here for too long
Edmonton AB
I had one. I saw that mod but never tried it out. I just crushed mine a bit... If I use one again, I'll be giving this mod a try.
Jordan
S
steve7680768
Guest
I am going to buy a new one one in the coming month... There will be a birthday of my wife in the next month... So it will be a surprise for her...
MeAtwagon
CTP_hookz
bristol ct
ive always just crushed the hat alittle for higher boost and have never had a problem. 1g dsmbov is prob the best bang for your buck bov there is
sdturbo
300+ Member
Eco Bricks Club
San Diego CA
I used to crush them but I started doing this mod a couple years ago. Does everything better with this mod and is less ghetto than crushing.
SevenFortyT
so i'm as new as it gets, but an avid student. what do you guys mean by "crushing the hat" or "crushing"?
sdturbo
300+ Member
Eco Bricks Club
San Diego CA
The little tin can on top of the bov houses a spring. If you crush that hat (stick it in a vise and clamp down on it until it crushes) then you increase the preload on the spring.
