Kjets On a Plane
- Nov 12, 2002
- Californicated Oregone
Got this hooptie '87 B230F in the beater wagon.
Very minimal oil use & leak down/no oil anywhere outside or volume of blowby coming out the oil separator box it w/strong compression w/thin headgasket & T-cam, but it's got the inevitable piston slap setup 2-run conservatively on 85-87 octane inconsistent OR & CA (so called) 'gasoline.'
No pitting noted atop pistons from severe pinging, spark plugs look a healthy tan on all 4 whardly any bore wear w/bore gauge measured in many places, otherwise.
Like an idiot/Moe-Ron/Jimbo-Elroy(ale), soaked the pistons in some ATF for several days w/cardboard over the top of the engine held on by a couple bolts to keep dust/debris out to free up the rings/their oil passages when the head came off.
Don't think the slap got *noticeably* louder & the compression got better, blowby was reduced & oil consumption went down (not that it was much before...one of those rare low mileage diligently serviced/highway driven/quality oil used/changed on time 240s you pull in the shop that's totally dry underneath / no blowby fountain huffing out the oil separator box & goop around the lifter buckets in the head or flame trap w/a head-cold, I guess? )
What could've been done differently to 'do no harm?' as a 'master backyard mechanic' lol: @ that) to as close to factory clean-room standards/repair practices/engine assembly & turn-key installation as possible w/what was at hand for tools/knowledge etc?
Carefully ridge ream it, tap the pistons out the top, blow around the ring oil passages with the hoffman-newyorker steam buzzing needle-jet/wand, but don't disturb the super hardened accumulated carbon on the sides of the pistons below the rings that holds the pistons tight to the shape of the bores w/minimal rocking on a crappy B230?
It's got the updated mopar ignition that doesn't seem to be uh...'#triggered' by the slap, but have concerns/it bothersome?
MPG is 'fine' (as expected, anyway; 27-29 in the flat @~55-65 @near sea level unloaded/nothing crazy heavy, nothing on the roof, not towing, 60 degrees, 60% humidity, smooth roads, A/C off, fan clutch working as it should//unlocking & progressively locking/freewheeling on the highway, OE sized tires, air guides in place etc, LH2.2 by all accounts doing its thing, valve clearances in spec (set a tad loose for MPG, longevity & emissions)) on the highway, warm up time reasonable, runs 'quietly enough' once hot/warm it up cautiously properly & gently & light cruise/decel down a hill &/or w/ external heat.
For maximum cheapskate skin flint long-haul em-pee-gees (MPGs) & the engine being 'correct' & original to the car (by all evidence/accounts/low mileage car of 'known' history), kind of *like* the '85-'87 skinny rod B230F & its attributes in this particular case;
Smaller main bearings, less friction/oil shear, skinny light(er) 9mm rods, it's auto-tragic so 180? hooptie center thrust bearing doesn't (shouldn't?) matter, anyway?
Obviously, best/better would be if the factory had a time masheen & could in a factory clean-room assemble w/'86-'88 w/tightest factory tolerances/quality control (from what I've torn down on '69-'95 redblock Volvos) recombine to give me what I want; later tall-gear oil pump & squirters, but '87 skinny rod low friction B230F for an '87 245 automatic workhorse/shop loaner car @ no extra charge that's still emissions compliant, lasts & returns optimal redblock 4-cylinder non-interferience low-fuss operation on dubious 'quality' gas.
Failing that, has anyone found a way to remove the pistons without reclocking the rings or disturbing their relationship to the pistons & bores or stretching/fatiguing them a bunch w/a ring spreader, clean the oil passages/around the rings & knurling &/or applying a swain-tech ceramic coating to the pistons & hand polishing that to the (used) bores optimally?
Install the later model 'tall' gear oil pump & some squirters & go go go?
Don't care about revving it over T-cam RPMs, just don't want to buy any new parts, or disturb factory fit/assembly/do no harm, but remedy the slap/rockin'-schlockin' pistons in the POS defective early B230 that they finally got around to installing a better oil pump/seals/squirters in (tho tooling was more worn out by then, engine metallurgy & e-fan turbo cars run hard in hot climates are fairly hopeless those years/less than optimal now 30+ years later of the redblock 4-banger).
Don't necessarily want to install a '93+ super low mile minty B230F as I actually *do not* want the 13mm rods, larger mains &/or sub-optimal fan clutches/cooling systems of the later donor cars or tooling/metal of the later engine & the '87 motor works 'fine,' it's just noisy cold (& to a degree, if you listen very carefully, hot, as well).
Hipermiling for the long haul rubber-tramping signing off...
*sigh* factory quality control 'questionable' piston steer 180? thrust short gear early oil pumps bean counter B230s
