ANTHUG740 said:my dad said they dont make much difference anyway, jus stick to the one the car has
you can improve the cooling with a larger flowing fan, but the biggest gain is in the little bit of hp gain by the engine not having to spin the fan. The other added benefits are greater temp control by what temp the fan turns on and off. The stock fan works fine if you are keeping it stock, add boost or other mods may require greater cooling needs. You decide.ANTHUG740 said:my dad said they dont make much difference anyway, jus stick to the one the car has
+1. On a n/a, you've got enough space to fit person in there!adrianpike said:
JohnLane said:Adrian how much faster was your car through the quarter for having that Lektrik fan?
1. I posted before my dad mentioned thatboostdemon said:this thread does not deliver.
1. if your dad says it doesnt do anything, then dont bother posting about it
2. the efan isnt a weight thing, its a cooling thing, or a sound thing, and at the very least a reciprocal friction thing
3. my dad once told me that 17x7" wheels wouldnt fit on a 240![]()
Gene_Gatech said:by removing the stock clutch driven fan which is driven by a belt you win in a few categories. (i'm still trying to gather the exact setup that i want)
{}First there is less frictional losses seen by the motor. = more power
{}second : less inertia the motor has to change when you hit the throttle = better throttle response + power
other benefits have been mentioned. Enjoy!
growley said:The major concern with electric fans is that they could stop working without you knowing and your motor could overheat.
But the advantages are the power that it frees up and also, your car won't have the work truck sound to it anymore.
