The EZ116K has two pins (pin 18 and 19) called 'selector pins'. By grounding these pins you will be able to modify the statical ignition timing - this means, that you will get a modified timing on part load. At cranking and full load at higher rpm's the timing will switch back automatically to stock values. Also it's not possible to switch the timing just in time - this means, the timing must be set before cranking.
