bennyg
- Oct 22, 2010
- Hi plains Big WindyWHY-Ohh
I had a stuck caliper on my 1991 740 w/ABS .I have never seen a piston so locked up ! I changed the caliper , but lo n behold , it was still locked up while the engine was running making vacuum.I turned the engine off and came back ,and the front brakes loosened . Next thing I did was remove the brake booster check valve to the booster. Upon removal the valve broke and a small piece of it fell inside the booster ! With the vacuum supply removed and plugged to the booster ,the brakes do release ,as you would suspect the brakes do not operate as they should , but it will keep the car moving until I figure out the final cause of the problem. .I have a few questions ,as I am basically CLUELESS as to the mystery that happens inside a brake booster . 1.] Has anyone out there in Bricklyn ,Brickdale ,or Brickville ever experienced this phenomenon of a failed booster locking up just the front brakes ? I dont think the rears were locked up , however they may have been , but due to the fact that the differential was turning/overcoming the resistance . It is not a fun drive on slick winter roads ...Does anyone understand the booster function and failure symptoms .2.] Will the small piece I dropped inside the booster housing cause me grief ?
