boostdemon
creative mastermind
- May 31, 2002
- Cary, NC
Some of the better threads for reading that get asked over and over again so you can catch up and maybe ask something new about the topic. I have noted what my exact search terms were and basically just grabbed some of the longer ones.
Feel free to add to the list
Transmission/Gear Ratio discussions
16v conversion topics: (searched "16v" in the subject line only)
Heads/porting/design/etc.. (searched for "head" or "531" or "405" in the subject line only)
Blocks/stroke/penta/etc.. (searched for "block" or "penta" in the subject line only)
Cam questions (A/B/K/VX3/V15/etc) (searched for "cam" in the subject line only)
Blow-Off Valves (BOV) (searched for "BOV" or "Blow" in the subject line only)
Limited Slips/Lockers/Diferentials (searched for "LSD" or "diff" in the subject line only)
- T5/Getrag/M46/M90 comparions - http://forums.turbobricks.com/showthread.php?t=104624
- 16v Turbo FAQ - http://forums.turbobricks.com/showthread.php?t=31900
- 16v DOHC vs. 8v SOHC - http://forums.turbobricks.com/showthread.php?t=2794
- 16v questions - http://forums.turbobricks.com/showthread.php?t=4748
- 16V tuned length turbo header available - http://forums.turbobricks.com/showthread.php?t=1518
- B234 16V - http://forums.turbobricks.com/showthread.php?t=3027
- Loads of Volvo 16v Info - http://forums.turbobricks.com/showthread.php?t=16750
- Valve Reliefs info request - http://forums.turbobricks.com/showthread.php?t=12163
- 16v Motor Build Up - http://forums.turbobricks.com/showthread.php?t=21873
- 16v Turbo Pictures - http://forums.turbobricks.com/showthread.php?t=26256
- 242GT 16v progress - http://forums.turbobricks.com/showthread.php?t=25259
- i think i found the cheapest 16v tensioner! - http://forums.turbobricks.com/showthread.php?t=19356
- ovlov.net DOHC on b230 tensioner/belt kit! - http://forums.turbobricks.com/showthread.php?t=6038
- 16V valve reliefs http://forums.turbobricks.com/showthread.php?p=1708755
- 160 vs P&P 398 vs 405 pics - http://forums.turbobricks.com/showthread.php?t=3670
- 531 head question - http://forums.turbobricks.com/showthread.php?t=22742
- Modified cylinder head - http://forums.turbobricks.com/showthread.php?t=16935
- HP Gain of the 531? - http://forums.turbobricks.com/showthread.php?t=18246
- What were the reasonings for 530 beating 531? - http://forums.turbobricks.com/showthread.php?t=8523
- can I use a 405 head? - http://forums.turbobricks.com/showthread.php?t=5413
- Update on B23 Stroker Engine - http://forums.turbobricks.com/showthread.php?t=20579
- Penta FAQ - http://forums.turbobricks.com/showthread.php?t=24675
- Old question rehashed: Maximum bore - http://forums.turbobricks.com/showthread.php?t=25961
- is short stroke/high rpm worth it? - http://forums.turbobricks.com/showthread.php?t=23427
- M cam vs. B cam vs. K cam - http://forums.turbobricks.com/showthread.php?t=1392
- Additional M vs. K cam testing - http://forums.turbobricks.com/showthread.php?t=1427
- Reveiw of VX Cam, IPD 2.25" exhaust (N/A) - http://forums.turbobricks.com/showthread.php?t=23522
- IPD turbo cam versus VX - http://forums.turbobricks.com/showthread.php?t=19799
- New Adjustable Cam Gear - a fine-tuning advantage - http://forums.turbobricks.com/showthread.php?t=1575
- BOV on b21ft w/ T3 - http://forums.turbobricks.com/showthread.php?t=1537
- Blow off Valve on an 240 turbo 83 - http://forums.turbobricks.com/showthread.php?t=11141
- LH 2.4 ECU info, BOV work or not? fuel cut @ what voltage? - http://forums.turbobricks.com/showthread.php?t=16099
- How bad is the rich spike if I put a BOV on my 740? - http://forums.turbobricks.com/showthread.php?t=4086
- DSM BOV mod for quick release and higher boost - http://forums.turbobricks.com/showthread.php?t=12105
- Whats the weakness in the Dana 30? - http://forums.turbobricks.com/showthread.php?t=22367
- 90+ Locker Differential In Pre 90 1031 - http://forums.turbobricks.com/showthread.php?t=15284
