77volvo245
- Apr 26, 2007
- Portland Oregon
15mm Spacer all round Adjustable pan rod and torque rods are needed.
MikeJr. Was fitting 225/45-16 T/A Firebird wheels all around with
25 mm spacers. He cut the entire lip off and panel-bonded the inner and outer sheet metal before painting the car. No clearance problems at all, with coil overs.
Can you come over and teach me to do that, but on the entire car? Thanks in advance.
That is the proper way to do. Very nice as always Mike.
Much easier to get it done if you are painting.
Harald, your car is jacked up thanks to Asher's butchery. You'll need someone like Mike to fix it and then repaint if you ever want it to be nice again. It's not just a modify then paint anymore. Fixing someone else's mistakes is always terrible.
Have spray can, will travel.I'm willing to bribe experienced folks to teach me how to do this properly. Preemptively planting the seed.
Originally they just need a light roll to clear the 17x9 et15 (et25 wheel, 10mm spacer) with 245/40-17 Federal SS595's and they didn't rub. Now we are switching wheels to the Style 42 BMW BBS wheels. They are 17x8 et1 (et20 wheel, 19mm adapter), so the offset because we are running adapters is where all the problems come in. I have rolled the fenders more and the 215/45-17 tires no longer rub. I used a 5lb sledge carefully, but heavily to roll the lip. I need to try the 225's in the rear again to see if they still rub. If the 225's fit I'd probably just stop there and call it good enough.
What Dave posted is basically how they modified Group A cars back in the day to fit race tires on them.
I think I want to raise the rear 1/2-1". It looks too squatted in pics. In person it looks fine. Also worried about when we have trailer loaded with 2 karts and car loaded with all of our gear. Might add a air bag helper system for when we are fully loaded.
This is from today where I did some more rolling and worked on the trailer that will eventually match. Car currently has 225/45's on the front, 215/45's on the rear and the trailer has used 235/45's that came with the wheels. Goal at this point is to have 225/45's everywhere. Trailer is lowered 2" and I added wider fenders to cover the 225's.
Me2. I come back to this thread from time to time just for planning purposes and as much to take a look at the Tuff's 245. I'm always looking at the combination trim on members cars.
This one without eye shadow and door cladding but with mud flaps and beltline moulding is out the park. My favorite snub nose ever.
Sorry about bringing up an old thread. But I?ll be in the same boat when I mount my Style 42 ET20 with 20mm adapters on my Wagon. I didn?t see any mention of the lowering specs.
Is the car on lowering springs or cut springs. And if cut springs can you share how much been cut front and back.
Thank you. And beautiful car.
