Yum.
I used the star holes and set the camber using a notecard as a feeler gage between the spring/perch and the strut tower, resulting in -.55 degrees drivers side camber and -.25 passenger. Still not where I want, but at least the numbers are negative now.
Now, there's nothing this car loves more than cold weather. When it gets under around 20 or 25 fahrenheit this car really feels like it runs sort of the way it should at full throttle. When it's warm out it always feels sort of unhappy when it's eating boost. I don't really understand it. Crappy cylinder head or something. There was a night a couple months ago where it got down to -5 or -10, I had the boost cranked up, it was running so good, aand the clutch is slipping. 7,000 miles, maybe a dozen or two launches.
Flattest flat flywheel plus 1.9mm spacer. The holes line up fine, it's just trying to fall off in the pic. New pilot bearing since the old one was toast. I think this engine might've been in the wagon the last time I changed it.
Sachs 883082.999767 - Reinforced Saab 228mm pressure plate. Regular stock dogdish turbo clutch disk sitting behind it.
Just a couple washers.
NOS FAG slave.
Had to tweak the pedal box a smidge. OEM hydro pedal return spring.
I'm pretty happy with it. It's smooth. It revs a little peppier. I don't think I needed to use that many washers, I stacked 13mm and 10 or 11mm would've probably been better, but I wasn't about to take the trans out again. Pedal effort is a little more, but still very tolerable. The pedal does sit higher than the brake pedal now, which I don't really like, but I don't think there's much room to adjust downwards. Even if I could, I'm already out of threads on the rod without the locking nut. I also fixed the reverse lights finally. I made a trans harness last time I changed the clutch so the reverse and 4th gear switches were all wired up properly, but I never thought to test the switches.
And so, the M46 fuse is now deleted.
