brickyard92
- May 14, 2009
- Lawrenceville,Ga
Replaced the front wheel bearings (sealed wheel bearing)assemblies in my 92 740. Used correct torque specs, anti seize, etc. Made sure the heat shields are clearing the rotors...
On The passenger side the bearing when on so smoothly,torque it down while turning the hub.
On the driver side i could not get the bearing to slide onto the spindle without having to tap it in with a wooden block. The old bearing was just as hard to get off on that side as well.
Now i can hear a ticking sound related to wheel speed, and its not brake related.I'm thinking i make have damage the wheel bearing while trying to tap it in with quite some force.
Why would the wheel bearing require force and not slide on like the other one??? Both bearing are Moog brand.
I've never been stumped on any repair on my brick in 20 years Any thoughts guys on this issue?
