77volvo242
- Nov 14, 2020
- California
I have a '77 242DL. But it's a bit of Frankenstein with a B230FT swap. Apparently engine management from a lh2.4. I purchased it this way so repairs can be tricky.
Car suddenly wouldn't start. Replaced the relay. Still wouldn't start.
Then I replaced the fuel pump. But I didn't do the fuel filter (Or is this an accumulator), because nuts were extremely difficult to break loose. However, car started immediately after replacing pump and drove fine for about 100 miles so I was thinking all was good. Then it wouldn't start. Got it to start once and run but was very tough to get started. Now not starting at all again. Sounds like maybe a tiny amount of fuel is combusting, but not enough to get it to turn over all the way.
So here's where I'm confused. I decided to go ahead and try to remove what I thought was the fuel filter. Finally got it loose and cleaned all the gunk off and the part is a Bosch 0438170034 - which is a fuel accumulator?
This is like a $250 part apparently, so before I replace I have a few questions:
- Is the accumulator a likely culprit?
- Does this accumulator have a filter built in? Looked like a filter to me other than having inlet and outlet on same side of canister.
- Anything else I should be checking before replacing this expensive part?
