Those 402's are what I run, they're typically referred to as CFI injectors around here, they flow something like 46 lb/hr, good stuff.
As for bypassing the main pump, it's easier than it sounds. You crawl under the car, unbolt the main pump, bring main pump to car parts/hardware store and buy the fittings you need to replace that pump with hose. I can't remember what fittings they are, I bet they're some sort of metric banjo fitting, and are probably different between 200/700/900 just to make life difficult. For the hose, you NEED to buy "fuel injection" hose from the car parts store. Carburetor fuel hose is cheaper and more common, but isn't rated for the higher pressures (45psi) of fuel injection, so it's not what you want. Carb hose usually says on it " not for fuel injection".
There are probably threads on this forum that tell you exactly what fittings you need, you'll have to search to find them. Heck I might have even mentioned it when I installed a walbro back in ~ '05.
