RAPTOR479
- Jul 15, 2022
- Dresden, ME
Had the day off work today so I decided the best way to take a break from my job fixing cars was to fix my own car, in this case just a plug change and an oil change in the driveway.
tunes supplied by the boombox on the roof in the form of Rush and Journey cassette tapes.
Everything went about as easy as one could expect doing the most basic maintenance to a B230.
The oil plug came out looking like this, but it seems to just be a combination of the K&N aluminum filter I had on the car (I had it in the trunk when I bought it) the Newly installed IPD magnetic drain plug from the last oil change, and that A cam swap from about 4100 miles ago that gave a decent bit of metallic sludge, but with no large pieces of bearing, the oil itself wasn't glittery
You need to get a little creative with the skid plate so the filter can drain (right onto the motor mount and crossmember)
Also got a much more gnarly angle of the damage caused by my adventures in New hampshire, I think the time is coming for some new stainless exhaust parts considering the manifold already leaks and needs to come off.
In other news I drove the car around for half a week with a busted maf and check engine light because the old bosch LH3.1 maf decided to unexpectedly kick the bucket, huge huge thanks to leecat for the hookup with a good 3.1 Maf
Until next time! Which will probably be the rear main as that's still leaking, is the consensus to fork over the money for the expensive genuine volvo seal? It's 35 bucks for a rubber ring but I'll pay it if it means I'm not dropping the trans again in a year
