fatcatbestcat
Professional Hack
- Oct 1, 2019
- Mississauga, ON (Canada)
put dracos on or cringe
I crushed those dracos for gas money.
Pulling the cam means replacing some seals, so I guess if I go that route I'll need to order some, and at that point I might as well add a valve cover gasket and maybe some rad hoses to that order... things sorta snowball from here.
It's still the home stretch though. And now that you know how quick and easy the front belt system goes together, that won't take much time to put back on when you reach that point. Everything else can stay on there (covers, balancer, WP, etc). You won't even need to move the WP. Just take the cam pulley off the front, do the cam work, then slap the cam pulley back on there afterwards with the belt in it, like before. It won't fight you since you already have everything where it needs to be.
I guess that's not so bad - for some reason I was thinking that I needed to remove the timing cover backplate, but I guess that's not attached to the cam in any way.
Still need to find the seals, though. I'm looking at a kit like you get from KGTrimning - although the description says it has a nice rubber gasket and not the nonsense cork one in the picture.
Nope. You will be able to sneak the cam out of there with the inner cover tin in place no problem after removing the front sprocket and the four cam caps. Sometimes in a 240 due to more limited firewall clearance (vs a 700 series) you may need to bend the inner cover forward a little bit as you pull the nose of the cam out, but that is fine to do, it will go back to where it was without issue.
That's a nice kit, as long as it does in fact have the one-piece rubber/steel gasket instead of the cork set. But you don't really need the manifold gaskets, so if you have to buy the VC gasket and cam seals a la carte, you can always do that as well.
At last check, Volvo dealers still sold the VC gasket at a competitive price, if it doesn't seem to be turning up readily in the aftermarket.
to have some of the parts needed - I need to get a glow plug relay anyways, and they might have it. Trouble is, it looks like a lot of the stuff on their site is on permanent backorder - or so it seems.
Those are cylinder head gaskets, not valve cover gaskets. You don't need that. Yet.
Did you try to put a wrench on that rear bolt and whack it clockwise with a hammer a couple of times? It's like impact gun, but for tight places.
Also, in hope of not insulting you - you do realize that you want to turn the bolt clockwise - when looking at it while standing in front of the car, in order to loosen it?
What's the number on the relay? I might have one, I'll look in my basement stash.
Ah - thought this was the one you needed
I don't even know anymore - I've seen black/yellow/blue ones...
I think the black relays are for the early cars, like 1979-1982.
Pretty sure there's a control relay and then the actual glow plug relay - this one goes in the engine bay - 240s and 740s use it
I thought about it, but I really don't want to bust my valves.
Also, considering the only tool that I can even fit into that space between the firewall and the sprocket is the fancy offset wrench v8volvo lent to me, I'm not going to risk damaging the tools with a hammer.
I did see the ad, but as a fellow project-switcher, I know how tough/irritating it is to constantly answer the questions of car friends who can't believe you're selling/why are you selling/it's almost done stick with it/etc. I'm glad to see that even though there's an ad up, you're still plugging away .
Yeah, you're right. NAPA does seem to have what they describe as cam seals for a '1983 Volvo 245 L6 diesel', but when I go check for an IDI 1.6 Rabbit of the same model year, I get results for the same part, but also a different part that looks closer to what I actually have. I cleaned up the seals that came out of my car, and checked the PNs... it's a Victor Reinz part that's apparently discontinued.I’m pretty sure NAPA can get you those cam seals in like a day. They’ve been used on basically every VAG diesel motor for 40 years (iirc). Imagine how hard you’ll kick yourself if after all this you have a Niagara Falls of 15w40 down the back of the motor because of a knicked cam seal.
