Yep its a 92+ 940 na radiator. picked it up from Cameron at IPD on Friday. Its a nice fit and a great radiator for what i wanted to do. Keep it looking as Volvo as i could.
I decided to start easy this am.....got the fan out of the box and started to see where I could fit it. Turns out that it did end up fitting on the backside of the radiator just by a gnats ass though. Has about a half inch of clearance everywhere so it should be good.
Its a 16" fan and should be enough to cool this little guy.
I also installed a fan switch directly into the radiator.....remember the volvo thing? Yeah, pretty sweet. So I used that and ran over to a relay tucked in right next to the battery and hid all the wires away so nobody can ever see them. No manual switch for now, I will see how it works and then change it if I need to.
So then, I moved onto a task that I have been dreading. Converting from a pull style cable setup clutch pedal to a push style hydraulic pedal.
This was a couple of hours under the dash and cussing. I used a generic GM master cylinder for the clutch. It was about 1/16th of an inch off from the mounting holes, so I hit it a little with the die grinder and bolted it in. Then I removed the pedal to convert it. The cutting fitting and welding were easy. The tough part was getting it in and out of the damn pedal box.
The stock one has a really long bolt that goes all the way through the top of the pedal for the pivot. Made it a real pain in the butt to get in and out so I revised their design. Tapped out the ends of the pivot tube to accept some bolts, then I put a set screw into the tube to pinch the pivot so you could tighten and LOOSEN both bolts and remove the pedal assembly. This made it much easier to get in and out. Good chage for those of you looking to do the hydro setup on your 240.
Also extended the pedal 2 3/4".
Ran a hard like from this down to an adapter and then to the stock t56 clutch line. Still need to bleed it but thats it.
Unfortunately for all your web followers, this is where I stopped taking photos.
I ran the heater hoses and buttoned up all the hose clamps down. Installed new plug wires from coils to plugs. Installed new plugs in all eight holes
filled up the tranny with fluid finished wiring up the ecu and buttoned up any other loose ends.
Installed oil filter filled with oil and hooked the battery up for the first time. Turned on the key and Ill be damned the fuel pumps both fired right up. Took one key cycle to find a leak in the fuel lines. Disconnect battery chase down fuel leak and recheck.
No more leaks, oil pressure light goes out when cranking......so lets see what she does.
No start... gave it a couple tries and sounds good but no start. Check a few things and then I see the ECU plug and realize that i did not plug the ecu in all the way, just kinda set the plugs in there and ran the 8mm down a couple threads.
Turned the key over and holy crap....she lit right off!! Kinda suprised me to be honest.
<iframe width="560" height="315" src="http://www.youtube.com/embed/BYD_4RI350A" frameborder="0" allowfullscreen></iframe>
So, i have a few loose ends to button up still. Pick up some fittings so I can button up the vacuum line situation, figure out a shifter, run some exhaust and button up the interior.
Should be on the road this week if all goes well.
Sean
