240 Hard Start, loping idle
KeizerBrickGuy
Sh*t pot stirrer
Keizer, OR
Hey TBrickers!
So my Wife's 1990 244(LH2.4, AW70) has been acting up the last year or so, so much to the point she doesn't drive it anymore(driving her Subaru). It started acting funny about the time the Garage Sale came around. Figured it had been two years since it's last tune up with plugs, wires, cap and rotor. I did the tune up in the parking lot before departing for home. It started up fine and drove great. Queue the cold nights/cool mornings, it will crank a couple seconds and then finally start, once it does, it acts like its going to die and the idle is rough and loping like a massive cam. If you don't give it gas fast it dies. Definitely not a fuel issue, can smell gas. I thought maybe the cold start injector is leaking or triggering, so I disconnected it. Not much of a change. It only does it on a cold start, but if it's been running and still fairly warm, it doesn't do it. Timing appears to still be set. Vacuum lines are good, accordion hose is split-free I can say it does hesitate super intermittently from as stop when accelerating. I have been so busy with our new house and life, I haven't had much time to look into it further. But I do drive it a few times a month to/from work to keep it happy. I am at a loss, Carl has been trying to help with my diag, thank you again, Carl! Local TBrickers, help in person would be a huge help.
UPDATES:
-Verified FPR is still good and functioning, was done 2016
-Vacuum lines are intact and good
-ECT sensor was done 2016
-Replaced FPR vacuum line back in December
-Intake accordion new back in 2016, still no cracks
-Intake manifold gasket done in 2016
-After testing ECT, resistance was incredibly high for temperature and no voltage coming from sensor when KOEO test was completed at the ECM pin. When unplugged and engine started, does not exhibit original problems with loping, rough idle or acting like it was missing.
FPR is a negative. I pulled the FPR from my 91 and it did the same thing. I replaced it about four years ago with a new Bosch unit. I did notice an exhaust leak possibly from the manifold-downpipe flange. It starts going away once it starts building heat. Thinking about cleaning the IAC tonight just to check the box as I haven't done it in a few years.
RE: "...does it on a cold start, but if it's been running and still fairly warm, it doesn't do it. "
Does it have spark, does it have enough fuel, and does vacuum fitness exist....those are the relevant questions.
A shot of engine starter fluid into intake before starting cold evaluates spark. Not easy to check fuel's rail pressure on 1990, but one could evaluate brake booster fitness via removing vacuum hose from it, and place a thumb over its fitting while starting. If engine is idling fine in cold/warm/hot conditions, then IAC is fine.
Unknown if LH 2.4 uses default "cold start fuel amounts," but if engine is near operation temperature, it may use previous "run fuel amounts," which is what is being suggested by your inquiry above. If true, then engine is sucking too much air at startup (like brake booster shot)
Original ECU? The pink label 561 and 556 ECUs are notorious for going bad. Apparently, some of the white label versions do the same.
It's got good spark, vacuum lines are good, it will flood itself if it's cold enough outside.
Could also be a (largish) vacuum leak. Inspect all of your hoses - especially the flame trap hoses.
Yeah, I double checked vacuum lines, they're all intact.
It is the original ECU. Most likely has the 561? It's an 89 build 1990.
Are you going to be at the swap meet this weekend? If yes, hunt for a 933, 946, or 951 ECU, then install it in the car when you get home. I bet that will make it run normally again, after the ECU calibrates itself while driving for a bit.
-J
Do diag!
Air leaks are the first thing to check. Spray around with brake cleaner and listen for a change in idle.
-J
I am hoping to get up to ipd this weekend, but not sure at this point. Low on funds for sure
Do diag!
Diag is what we do! Hoping to get a solid diagnosis by this weekend.
This sounds spot on for a coolant temp sensor issue, or wiring for it.
Test the CTS
Check the grounds on the manifold. The round grounding rings actually have a butt connector about 6" into the loom there, where all the grounds go into a connector and come out as one wire with a terminal ring. I flowed solder into that junction and my CTS issues (hard cold start, Sooty marks, rich under boost) all went away.
I replaced the CTS when I replaced the FPR, but for due diligence I need to check it and the wiring.
On an unrelated note, who has the green book for the 91+ 240 AC wiring and design?
CTS/FPR...."If you don't give it gas fast it dies."
...press pedal 3/4 way down, hold, then start.
Not a vacuum leak issue, but ECM pushing additional fuel...if ECM's CTS was replaced, and not the temp gauge sensor, then ECM's ground side to injectors must have a longer duration to bring about too rich of a mixture. I'll assume idle switch is functioning correctly.
A fuel rail test might detect if an injector is leaking down....cold start injectors have had problems....so in the morning, if intake hose was removed, then rotate throttle plate on throttle body, and smell for gas...
Myself, I removed intake manifold, and had all five injectors tested/cleaned...100k miles on 1990-240...main injectors needed a cleaning.
Correct, I replaced the ECT for the ECU. I need to spec out the TPS tomorrow and possibly readjust it, if needed. I have been looking for my injector noid light set to check the injectors before I pull them. I've thought about pulling them and getting them cleaned/tested in the past. It should probably be done either way. Ran out of time to test the CTS and it's wiring.
I might want to replace the exhaust gasket that is leaking before I really do anything else. That could very well be it.
...I've thought about pulling them
I think cold start injector MAY be removed and evaluated on vehicle. Electrical plug will have to be removed, but maybe those two bolts can be removed, and slide out cold start. If true, then prime fuel pump...
Yes, one may have to remove IAC/intake hose/etc....but if intake gasket has not been replaced in years, jerk it all off, and replace PVC box, hoses/etc.
When engine is warm, fuel will vaporize...in cold weather, a slow process...hence, a leaking injector...most likely, cold start. It don't get used much, and line debris goes downhill to it.
I unplugged it when it didn't want to start back in January and haven't plugged it back in. The intake gasket was replaced when I did the ECT. I'll start it up tonight to check it tomorrow morning before I head to work. Thank goodness my head cold is clearing up so I can smell. :roll:
...leaking is a mechanical issue, not electrical.
"Among the signs of a faulty cold start valve are difficult starts, no start at all, engine flooding and start/stop issues"
I understand that. But it may not be mechanical. This vehicle is old enough that a simple sensor or connection could be bad. In a perfect world I would have this fixed by the time I leave for NTC next weekend
