hardware/ threads faq
foggyjames
Ryan's spanner monkey
Lincoln, UK
If you're talking about an LH2.4 engine (1990+?), you need the blank to be in the starter hole with number one piston at TDC.
cheers
James
foggyjames
Lincoln, UK
cheers
James
cleanflametrap
near baltimore
FI temp sensor threads LH2.0/2.2/2.4 (ECT)
S
smokeyfan1000
Guest
240 steering wheel nut- 27mm deep socket (hope not a repost)
True , Also, just so happens that a standard 1 1/16 deep socket will also fit steering wheel nut, in case metric socket is unavailable
242Bleek
k-jet groupie
Brooksville/Tampa, FL
Just thought id throw this out there. I need to know the thread size on the one coolant pipe plug that comes on the 16v head by the temp sensors. Id like to assume it's 1/4" npt but I could be wrong, just need to be sure
BLS
Manassas, VA
Starter bolts
Didn't see the starter bolts in this FAQ. I had to cut off the heads and then lost the rest during my slow rebuild job on a 1990 240DL.
Fuse
Finland
What's the thread size for an EGR thermostat valve in redblocks. It's the one below intake manifold and has two vacuum ports. It goes in to the head next to the temp sensors.
Thread is tapered so I would suspect NPT but if someone knows for sure..
