- Mar 14, 2007
- Norwich, Norfolk, England
I have fitted my '92 b200ft powered 940 with a low milage '98 b230fk block after the head gasket on it started to go i took the head off and you could fit a small child in between the piston and bore. After having put it all back together again with the new block but the old head, I realised that i was an idiot and the reason the head gasket was still blowing is I had not had the head skimed ( please learn by my silly mistake ) so i took it all apart again took the head to a machine shop and he had to shave 12 thou off the head to make it flat again. after fitting it along with a new volvo gasket. (I finished this at 10pm yesterday) I took the car for a slow drive, with the boost at 7psi never going over 3500rpm AND after 10 mins there was steam (white smoke ) bellowing from the exhaust, it emptys the almost the entire cooling system in a minute, the header tank bubbles like a geiser and it is genrally a pig to drive, even worse than when i started but it appears there is no oil in water or water in oil. so does any one have any idea what might be going on ? is there somthing I might have damaged (turbo)? fitted wrong ? OR has working single handidly on this all day for the past week just made my mechanical skills as bad as my puncuation and spelling ?(sorry its taken me 30 mins to write this) just so you know the car is a '92 940 originally b200ft now b230fkISH with 15g turbo , 960 afm , 440cc injectors, 3" down pipe and exhaust , no cat , ebay alloy intercooler, adjustable fpr & freds ignition chip curently with a standard 2.3 ecu I know i need to do a cylinder pressure test, but at the moment i cant get the car in my garage , its raining real hard and i genrally cant be bothered so WTF ?
