nemesiss45
- Oct 12, 2025
I picked up a diesel 245 yesterday. The price was low enough, I wasnt stopping to ask questions, but when i got home and started inspecting it, I realized it is a 245 Turbo that had a D24T swapped in.
I knew picking it up that it was not running, but the guy said it had been running (poorly) but was no longer running.
The wiring is all over the place... the factory ignition switch was chopped and there is an aftermarket switch that seems to enable a push button start. There is a switch for an aftermarket fuel pump. There are 2 other aftermarket switches that I have no idea what they do yet, but on or off, the thing won't try to fire.
The fuel pump works, and I am getting fuel through the filter, but not seeming to get any return flow and its not even trying to kick off in the cylinders, so I dont think I am getting fuel there.
I tested the fuel shutoff solenoid, and it does no seem to be getting power with any of the switches turned on. I jumped it, but still was not trying to fire.
I have like no experience with these diesels, let alone in an engine swapped vehicle. I am planning try to trace the wiring, but was hoping someone could tell me what electronic components need to be getting power for this to run... obviously the starter, which is good. And i know the shut of solenoid... but what else do I need to check on? Will the thing start without power to the glow plugs? I havent gotten as far as checking those yet.
Any help would be appreciated. I have wanted to play with one of these for a while, but I definitely need to learn the ins and outs of it. And it would have been nice to start on one that wasn't quite ao much of a hatchet job... but like I said, the price was right, lol
