hessam69
- Jun 19, 2009
- Sydney, Australia
So my 940 water pump started leaking from the bottom. It was fitted 2020, 18,000 kilometres ago.
Found no movement in the bearing. Removed it, and saw the impeller had contacted the housing and removed material. What seems to have happened is the shaft has moved inward, reducing the gap between the impeller. This caused friction, which generated heat, which blew the seal. I could also hear a screech sound upon engine shutdown.
I am now trying a GMB (made in Thailand) pump. Quite cheaper than Hepu pump too.
