bugjam1999
- Aug 18, 2015
Did you manage to fix this?
Neat Roy, but here is what the Green book 2.4 service manual says. Unless I am reading it wrong sure seems like it don't work if tps clicker ain't clicking right or ain't closing all the way. Yeah ECU don't care, but if throttle body not closed all the way then motor revvvvvs higher...
Enlighten me please ohh glorious moderator. Maybe your bible is a different version perhaps if you even got one....
Book says idle mainly controlled by engine temperature, maybe your temp sensor bad.
Well 2021 ended with progress somewhat
Went to Groanman's and plugged his oscilloscope: we found out that there was no speed signal coming out of the cluster back to the ECU
Swapped the odometer unit with a good one (tested and a signal was coming out) the engine was still idling a bit high at around 1000rpm
So we adjusted it through the throttle body screw and it sat around 750-850 rpm
After several test runs at over 3000rpm it always came back to normal so I felt pretty confident and drove back home: 40 km of keeping the revs up over 3000rpm and checking it came back to normal... until I got about 3 blocks from home... it idled back at 1000rpm and did not reduce. When I turned it off and on again it was back to normal
At least its not 1500 like before...
Story leaves the question: Was the behavior consistently paired with the 311 code set? Thought you had already swapped speedometers or clusters several times?
You don't adjust the idle on LH 2.4 via. the throttle plate stop screw. The IAC does all of the idle control. That's why it still isn't idling correctly. Back the stop screw out until the throttle plate is completely closed. Then, run the screw back up to the lever arm until it is solidly against the arm, yet, doesn't move the arm. The throttle plate should be completely closed. Now, turn the stop screw 1/2 turn in the direction that opens the throttle plate. Tighten the lock nut. Next, re-set the TPS. This will allow the ECU to properly control the IAC and keep your engine at the proper idle speed.
https://www.brickboard.com/FAQ/700-900/EngineSensors.htm#ThrottlePositionSwitch
where did you get that chip? have the same problem. thanks in advance.I had a very similar problem. My '93 240 B230F M47 would report a 3-1-1 error at speeds higher than 3000 and idle at double that until the ignition was turned off. The problem was in the speedometer signal output from pin 31/6 to ECU pin 34, caused by a faulty chip in the speedometer. After replacing the chip everything is fine.
I don't see the UAF 2115 for sale from any reputable suppliers. But you can get them from China (aliexpress/Amazon/ebay). No way to know if those will work to spec.where did you get that chip? have the same problem. thanks in advance.
