How wide we can go?
HazzaVanBob
Volvo 940 wagon 1997 Hi, I was looking for some info on widest possible wheels BUT without Rolling, bending etc. and without removing liners. Planning On increasing and upgrading suspension so tyres that are high profile or thin wont work at all. Advice needed ASAP. Thank You in advance.
225-50 is an easy fit on a 7-8" wide wheel: 15" (slightly shorter then stock) or 16" (slightly taller then stock) This is from memory.
If an inch wider is 25.4mm wider, and you want the same distance from the strut, subtract half that (12-13mm) from the offset.
I don’t remember the offset of a rwd 7” factory wheel like multi-x, but the info is available if you search. I have not felt compelled to add this to my work load.
