Alan29
- Jun 23, 2019
- Jax Adjacent, FL
I found it works best to use something to knock shit loose while you suck from the access points inside. I used a 3' length of solid core copper wire used for normal home grounding wire. I bent the one end into a small oval then shoved it in down the side whilst the shop vac was sucking from the vent area in the interior kick panels. Then worked back sucking from the other points in the rocker. Worked great.
FWIW this was an 83 that had the footwell fresh air vents on both sides. I assume those same areas are just blocked off with a plate in the later models?
