D.E
tvåförti
- Sep 15, 2010
- Mora, Sweden
Looking for some more armchair mechanics!
My M47 240 has had a high-pitched howl that increases with speed for the last five years or so. It’s hard to hear where the sound is coming from since the whole wagon interior acts like a resonance box.
It’s usually when it’s cold outside, and only for the first few miles and then it goes away. It changes with speed but is present in all gears including neutral.
I always just assumed it was the diff bearings until I swapped the rear axle for a LSD unit with fresh oil this summer and the noise persisted. Then I changed my focus toward the driveshaft center bearing. Well, that is now replaced as well with no change. I replaced the transmission fluid with fresh ATF at the same time.
So what do we think? Could it be the gearbox itself? Did I swap in another bad rear axle? It didn’t howl in the donor car as far as I can remember.
