760 Hydraulic clutch fork
urbanwheeler
Santa Cruz, CA
Is it possible to remove the clutch fork without removing the transmission (the hole in the side of the bell housing is large enough, and I can get the spring off the pivot ball thing, but it won't slide out like it looks like it could). I cant tell if it has another retainer clip holding it to the throwout bearing.
heres the one my car has:
I am hoping to be able to remove it, so I can make a better pivot point where the slave cylinder pushes against it (instead of the busted off plastic nub).
Keep in mind that the plastic nub pushed through because there is something wrong internally.. The slave/nub was less than a year old!
