I know its not rwd but I need help xc90
GTJordan
Been here for too long
Edmonton AB
Also is it OK to disconnect the shaft and drive to see if that's the issue
Which shaft?
The prop shaft has to be taken out of the pinions on both ends. You can't leave one in. I remove it completely when I'm at work.
You can't remove a front axle and drive it.
The popping while turning makes it sound even more like a bad front axle (or your bevel gear has completely failed, but you'd be hearing alllllll sorts of other terrible noises)
Jordan
Wilford Brimley
Is posting from the grave
Marysville, wa
Which shaft?
Jordan
I was referring to the rear axle, my mistake...also there aren't a ton of bad nosies at all just the aforementioned pop. I watched a video of removal...doesn't look bad except where the (haldex?) Side gets kinda stuck
GTJordan
Edmonton AB
I have a punch that I've bent at about a 45 degree angle that can be inserted in the unthreaded hole, then the punch hit with a hammer to pop it out. Some can be a real pain. The front one will either fall out, or it is going to suck since there isn't as much room as the rear.
Jordan
threewagons
i am the liquor
LFK
May not be what you're describing, bout our XC90 felt really unstable at speed when the control arm bushings were shot when we bought it.
